daschild hood liner
daschild hood liner
Hi Everyone:
I received my daschild hood liner today. Fits great and looks great but now I guess because of the added weight the hood will not stay up so it looks like I'll be replacing the hood struts. Also before you install the liner don't forget to remove your option code sticker and replace it onto the liner. Mine came off without any trouble but if it is a little difficult to remove you could coax if off with a hair dryer. Tony
hmmm... I won't be removing the sticker... I thought this liner was help on with clips of some sort?
It doesn't use a double stick tape or anything, right?
edit: I answered my own question: https://rennlist.com/forums/showpost...9&postcount=36
Personally, I'd rather keep the options sticker where it is. Not sure why... just seems "right"
Wow, you got yours quick Tony!
MarkD
I think (hope) you're right, its held on by plastic clips that attach thru the "schild" to slots on the bracing on the underside of the hood. I believe Tony was talking about a factory sticker that was on the underside of his hood, that he moved onto the "schild" so he could still see it.
MarkD
daschild hood liner
Hi Everyone:
The liner is held on by plastic tabs that have threads on them. Once they are installed they are very difficult to remove without damaging the plastic tab. They most likely would have to be replaced. The only reason I mentioned repositioning the option sticker was in the event you needed to access (see) the sticker you would have to pop some of the tabs off thus damaging the tabs and have to replace them. Just my 2 cents worth. Tony
Hmm, I'll have to think about the sticker thing I guess. Or get some spare clips/tabs. I'm am jealous that Tony already has his, I'm gonna have to wait until the 15th for mine. But I'm all the way on the other side of the country.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I would leave the sticker where it is, rather take a picture of it for future reference. Or, as I did when getting my first 993 home, memorize them
Too Old To Remember My First Time
1 Post
Why not just take a nice digital picture of the option code sticker, print it on some Avery or similar self adhesive paper and place that on the liner?
Basic Sponsor
Das SCHILD hood liner
Hey guys, we have a saying... if your car needs new deck lid shocks with the schild part, it needs it without.
Let's face it, if you, or the previous owner of your 1974 - 1998 911 has not replaced the deck lid shocks on your front and or rear deck lid, you will need to, due to the simple fact that they wear over time. How many of you are carrying some sort of stick in your cargo hold to prop up your lid? I have met a bunch of you.
We try to point this out at the beginning of a GB. The following link: http://www.dasschild.com/shocks.htm will take you directly to our shock order page.
If enough of you want to get a GB going on the schocks, I'll see if we can get the same, or close to the same discount on the deck lid shocks. I have replaced factory shocks with the Weltmiester brand. They are a quality product!
You won't be able to install them as easily as the schild part, but I think most of you should be able to do it in an hour or so.
Basic Sponsor
Deck lid label
I think most of us, or our mechanics will use the label for paint code info more than anything else. The paint code is on the label and also on some models, in the cars book, see pic.
The number is usually four digits long and starts with an "L" or it is three digits long. It contains letters and or numbers. Pretty easy to jot down or put in your book if it's not already there.
If for some unfortunate reason your car finds itself at the body shop (Hopefully not for dents to your deck lid) hehe, The body shop knows how to remove the push clips without damaging the part, the clip or the lid. We can do a GB on the tool that removes this type of clip also? Maybe we'll send the tool with an extra set of clips just in case.
The GB will close Monday, most parts have been shipped. Guys have a great weekend!
SCHILD
SCHILD
Mine came today, and I had it on within about 5 minutes. Here are before and after shots.
To me, the black coordinates with the black finish inside the trunk, so I see no reason to pay a lot more for matching the color of the liner to the car color.
