993 Forum 1995-1998
Cab top issues...
Old Jul 6, 2008 | 10:46 PM
99three's Avatar
99three
Default Cab top issues...
A beautiful day today and I wanted to enjoy the sun with the girl. Much to my dismay the cab top does not want to retract. It was working fine last week! The motor doesn't make a sound at all so I checked the fuse (#13) and it seems fine. Any suggestions?
Old Jul 6, 2008 | 10:51 PM
murfysflaw's Avatar
murfysflaw
Wallflower
Do the latches unlatch and it just won't go back or it doesn't even unlatch?
Old Jul 6, 2008 | 11:01 PM
99three's Avatar
99three
Doesn't unlatch. Looks like there is no power at all.
Old Jul 6, 2008 | 11:08 PM
briefescape's Avatar
briefescape
It could be one of two things e brake sensor switch or the main switch . Both are easy fix .
Cheers Guy
Old Jul 6, 2008 | 11:33 PM
99three's Avatar
99three
Cheers Guy
OK, I had my short shifter installed a few days ago. Could this be the culprit. Are there any diy fixes for either issues you just pointed out?
Old Jul 6, 2008 | 11:42 PM
CN's Avatar
CN
Escapee
Probably the parking break indicator contact. If the light on the console doesn't come on with the hand break, that is the problem. If so, I know everything about this issue so let me know if you need help resolving it.
Old Jul 7, 2008 | 01:32 AM
99three's Avatar
99three
BINGO! I just double checked. The parking light does not light up when it's engaged.
Old Jul 7, 2008 | 01:57 AM
briefescape
here is a link at removing the console to access the sensor .
http://www.pcarworkshop.com/index.ph...center_console
Old Jul 7, 2008 | 02:10 AM
CN's Avatar
CN
Escapee
PM replied to. I can fix this thing in about 16 minutes if the plastic holding the conductor clip is not damaged.
Cheers,
Old Jul 7, 2008 | 10:16 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Sounds like your problem is the parking brake switch but in the future you also have the Cab Top Controller that's under the driver's side dash. It's tucked up under another unit that you have to remove first and hard to see.
On mine, it had cold solder joints that had been repaired previously, I repaired it once myself but then it failed and was too far gone for me to repair so I ordered a new one from Sunset. Haven't had any problems since.
BTW, I converted my top to manual a week after I got the car. The Cab Top Controller still controls the front latches.
