doing a "tuneup", what else should i do?
I'm changing;
plugs, (fun fun fun!)
plug wires
dist. caps and rotors
I've previously changed the Air and Fuel Filter.
what else should i do while in here?
does the Idle Solenoid Valve require any PM?
cheers
Craig
IMO, consider changing your lower valve cover gaskets before they start leaking.
ISV is easy: http://p-car.com/diy/isv/
2. * Change spark plug wires-Beru
3. * Change air inject check valve (SAI check valve)
4. * Change both cabin air/pollen filters
5. * Change the engine air filter
6. * Change all 12 spark plugs (yea, esp. # 12 that, I know, is a PITA)
7. * Change both distributor caps
8. * Change both distributor rotors
9. * Change fuel filter
10. * Change engine oil (I will supply 10Q Mobil 1 - 15W50)
11. * Change large oil filter
12. * Change small oil filter
13. * Change A/C compressor drive belt
14. * Change Alternator drive belt (inner)
15. * Change Alternator drive belt (outer)
16. * Change power steering belt
17. * change ignation coil wire
18. Change manual transmission fluid. REDLINE
19. Bleed/flush the clutch hydraulic system
20. Bleed the brakes
Note The brake system was completely flushed less than 7 months ago so the
(ATE super blue)
21. Please perform all the (remaining) normal checks, lubrications etc. as
specified in the
60k service interval. In particular, please re-lubricate/check tolerances of
the manual
transmission gear-shift linkages/bushings etc.
22. Remove and Clean ISV
23. Replace front hood shocks
**THE UNEXPECTED**
-belt tension indicator-bearing was froze.
-Ignition coil-shot for the most part
-Distributor rebuild
http://www.pelicanparts.com/catalog/...BASkit_pg1.htm
I bought my plug wires from autohausaz.com Beru
car has 22K miles.
probably no need for distributor rebuild, though i do have a spare "slave distributor" drive belt waiting to be used.
<snip>
specified in the
the manual
I'm buying a wire set from Mark Robinson of Austin Texas.
I highly recommend you consider contacting him if you need wires for ANY P car project.
www.928turbosports.com
be safe
Craig
