Which power bleeder?
I bought the less expensive Motive unit (about $45.00) and it worked very well. I just needed a longer pc. of 1/4" tubing which I had anyway. Just remember to take out the small plastic cup in the resovoir below the cap before you begin (ask me how I know)
Over on the 964 board a fellow suggested adding an air coupling to the 1/4" line. It works great when using the Motiv dry. Put the female coupler on the tank side of the line, down near the brake reservoir end. When you pull the coupler apart the pressure remains in the Motiv tank. And, you can more easily remove the cap and short stub from the brake reservoir. Refill the brake reservoir with fluid and reconnect the Motiv tank. All set to go with little or no additional pumping.
