KW Suspension upgrade?
Hi I'm a newbie to the forum but I hope you can all help.
Does anyone have any experience with KW Suspensions? I did a search but found very little info here.
I'm ready to upgrade the suspension on my '96 C2 and was all ready to go with the Bilstein PSS10 kit. However, when I spoke with http://www.manthey-motors.de they only use KW suspension. I tend to 'trust' Manthey as there is no denying their expertise. I think KW seems to be a more popular here in Germany than in the states, hence the dominance of the PSS9/10 system.
For now, I plan on using the car about 95% street and only 5% on the track. It's purely a fun car so ultimate comfort is not a problem, however I do tend to take it on long road trips. Over the next five years or so I plan on modifying the car with the focus to take it on tracks such as the Nurburgring. I've read many comments where people have said that they very quickly outgrew their PSS9 set-ups on the track. I want to avoid this but I still need to drive the car on the road for now. Can someone put this into perspective -at what level will I need a pure track set-up?
I've also looked at Moton's and JRZ. I've read everyones opinions on how these compare to the PSS10 set-up but don't really know how they compare to KW??
Moton or JRZ would be waaaaaaay overkill for a 95% street car. Either would be far superior to KW, PSS9, PSS10, JIC, etc. but also 3x the price.
Does anyone know the price for Moton or JRZ in Europe? I see that both are located in the Netherlands and could go there for the install. The KW set-up at Manthey with corner balance is going to run over 3000Euro!
I have KW v2 on the turbo along w/ RS sways and the suspension is well sorted out...very happy with it but I am thinking of upgrading to KW v3 and putting the v2 on another car.
I just want to add that while the car will be used 95% of the time on the road, they are silky smooth German roads -i.e. high speeds the autobahns, lots of twisty stuff in the Alps and the occasional trip to the 'Ring'.
Therefore, a 'street' set-up for U.S. cars might not be the same as for cars living in Germany.
David, is there any chance you could take me for a short ride in your car (I'm periodically in LA)? I've been really unhappy with my Bilstein HDs (too much compression dampening for the driving/roads I do). Seems as though KWs might be a good alternative although not many people have them.
Also, your ride height will be silly-low and, unless you are trying to roll beer cans, impractical. Also, you will be limited in the amount of positive camber that you can get in the rear, meaning you will have too much negative camber for a 95% street car. You will have to get ERP links in the rear to give you full adjustment.
Stick with JIC's or maybe the KW's if they prove to be a good product.
I would love to except that my car in LA has a RS/RSR setup; the KW v2 is on a car in Hong Kong...but if you are ever in Hong Kong then you have an open invitation for a ride!
AFAIK KWs are not that popular/common in the U.S....perhaps they are not officially imported?
How long have you had your KWs?
How would you describe their build quality?
In you experience, can the shocks be set to provide a reasonably compliant ride?
I don't necessarily need a plush ride, but I do want shocks that can be set not to wallow while at the same time not be so non-compliant that the car steps out on mid-corner bumps. My Bilsteins have so much compression dampening that the car skitters all over the place when encountering a small imperfections in the road. Not confidence inspiring to say the least.
Thanks in advance for your help!
Joe - The KWs were installed on the car by the PO and I've had the car for about 4-5 mos now. The PO's mechanic (who is also mine) did a good job of tuning the settings for the street; I have not changed the settings and probably will not do so....overall I'm pretty happy with them. The v3 are three way adjustable vs. the v2 which are only two, which is part of the reason I am thinking of replacing them (plus the other car could use a coilover setup so I'd kill two birds with one stone).
Thanks David. I do believe KWs are officially imported - they're just not very well known in the US.
I have heard from a lot of people KW are some of the best. They tried to make a push into the import scene a few years ago and failed miserably. At least from what I could tell. I have been curious about getting these over the PSS10. I had one off Bilsteins from a Japanese racecar on my RSX, and no one could believe just how well the car road on these evil streets of california.
