All this brake painting got me thinking...
My big reds are a little tired looking and the clear has chipped off in several places. I have read all the recent threads about the products people use with overal great success; however, I have never "loved" the bright red contrast with my Arena Red body color. Yellow looks better than red but is a little flashy for me. So, my thought was to paint them to match the body; however, the problem I have is my lack of paint knowledge.
Can a painter mix a custom color of high temp paint (what would I ask for)?
What is the difference between high temp and regular paint?
Which is better for this application, paint or epoxy?
Any advice/thoughts would be appreciated.
Thanks!
Thanks!
Seared
Adam,
Check with Paintscratch.com - I've ordered Polar Silver in a spray can and it was a damn good match. I used the paint to finish a set of brake ducts.
Andreas
Andreas
Not any good ones, but you can see the caliper here. Matches the stock silver wheel paint fairly well.
https://rennlist.com/forums/attachme...1&d=1211986106
I've heard the powdercoating process can damage the seals if not done properly and I'm not looking to remove them from the car if I can help it! Have you powdercoated yours?
What about the epoxy vs. high temp paint issue?
Duplicolor has a heat tolerant clear spray can of clear that says good for up to 500F for short periods of time. I used that over their primer and red after applying new decals.
