993 Forum 1995-1998
Fuel additives
Old Jun 16, 2008 | 09:41 PM
Dr. No's Avatar
Dr. No
Originally Posted by Steve Weiner-Rennsport Systems
Louis,
We've had the best luck with LubroMoly two products: Jectron & Ventil Sauber. Their functions overlap a bit but a can of each into the tank at fillup time works absolute wonders when you go drive it hard for a few hours afterward,..
Steve - add them both at the same time??? How often?
Old Jun 16, 2008 | 10:27 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Yessir, absolutely,..
It depends on annual mileage, but a twice a year treatment helps keeps the injectors at peak performance and the intake valve stems clear of soft carbon.
Old Jun 16, 2008 | 10:47 PM
race911's Avatar
race911
Louis,
We've had the best luck with LubroMoly two products: Jectron & Ventil Sauber. Their functions overlap a bit but a can of each into the tank at fillup time works absolute wonders when you go drive it hard for a few hours afterward,...
Have either of these changed formulations over the years? Used to use it at my shop in the mid-late '80's. Never had occasion to pull an engine apart that we used it on regulary........that I can remember, anyway. But it came highly recommended.
Old Jun 17, 2008 | 12:23 AM
Nope,..still the "good stuff" in my book,...
I have no reservations about using these products in anything with a 4-stroke engine.
Old Jun 17, 2008 | 10:35 AM
fast_freddy's Avatar
fast_freddy
Damnit! I was hoping to use it in my Saab 96.
Old Jun 17, 2008 | 12:42 PM
If it suddenly sprouted poppet valves, you are good to go,....
If not, put just a bit of Castrol R in the gas and make your neighbors smile.
Old Jun 17, 2008 | 03:31 PM
geolab's Avatar
geolab
make sure you use the stuff two tanks before an oil change. It is well indicated on the lubro moly it is best to use before an oil change because the oil gets some of the stuff in it.
I used to hear from old-school that it cleans the tank as well.
Old Jun 17, 2008 | 04:01 PM
allffy's Avatar
allffy
Hi all, Thanks for the info, big help
I cant get Jectron & Ventil Sauber in Ireland, anyone know a site that sells them?
Thanks again
Old Jun 17, 2008 | 04:03 PM
samsnead's Avatar
samsnead
Just google it, I found a couple of online dealers that way. Dont know if they will deliver to Ireland.
Old Jun 17, 2008 | 04:12 PM
allffy's Avatar
allffy
Cheers, found one
Thanks again
Old Jun 18, 2008 | 03:52 AM
geolab's Avatar
geolab
Thanks again
lUBRO MOLY is LIQUI MOLY in europe. (try guessing why they changed the first word for the US market)
The brand is german and the factory is in france. regards
File Type: jpg
