DIY Daytime running lights
Has anyone any information on how I can do this myself. I live 500 Km from the closest dealer and I don't trust the local shops as they have no p-car experience.
I did a search and did not find anything on DIY only that others have had it done.
If you search for : daytime running lights, you should get 15 threads
If you have a US car you will have to add wiring and a relay as the US cars do not have wiring to the dlr relay position.
Maybe the last post in this thread ? : https://rennlist.com/forums/showthre...running+lights
And disregard my posts in that thread. The US cars are not prewired
I don't know them personally, but i do spend quite a lot of money at their shop
Espen, who works there is probably one of the most knowledgeable Porsche guys in Norway.
They know a lot about the "older" cars (which the stealer completely neglects) and the service they provide is first class !!!
(no affiliation)
Have you had your RUF at their place ?
(no affiliation)
My DRL's are achieved with an extra (standard 4 pin) relay to fire the driving lights - not the headlight low beams. I have not bothered to trace the circuit, as it was previously done . If interested, I could take a look inside the CE box.
No never serviced my car, but I met Espen a few years ago in Essen Germany and I consider him a friend.
We have identical Ruf CTR-2's
Say hello from Levino next time you are in the shop.
I will
they have a couple of nice CGT's in the shop now, here is one : http://autotuning.no/biler/carrera-gt
since you are in Canada,eh ,get a daytime running lite kit from any auto suppy store,wire it in according to directions and locate the relay behind the R headlight. Run the wire to your fusebox for Power. or come and see mine in Stoffville. Andy
I'll check out my CE tomorrow AM to see how it was done. Your solution looks more elegant
This set up uses the fog lights as does my Cab which is a Canadian factory car with relay.
