Can we not drive these in the rain?
R.I.P
I even drive my cab in the rain, top up of course.
Hey bart, what color is aDventurine?
If you have water seeping underneath the windscreen seal, make sure to have the seal and screen removed by a good bodyshop, and have them look for rust.
I had the same issue on my 964. From the outside it looked like an innocent bit of surface corrosion, but when we removed the screen there was water and rust all over the inside.
A ticking bomb!
A ticking bomb!
My car is in the body shop. Blowing out the AC drain may have fixed it, as after I did this I didn't notice any more water in vent. However, I didn't drive it in any hard rain after that. The slight rain I did drive in is what sent my car to the body shop.
Judging from your pics of your windshield seal, it is NOT installed correctly, and even if you don't get cabin water leaks because of it, you probably will have water inside the windshield frame...and then rust.
Addicted Specialist
