No power, no response.... :-(
Hi there.
I have now spent the last 5 hours searching and reading of problems with high mileage 993s. I am a complete tool when it comes to technical questions and my abilities doesnt go much further then changing battery.....
So my problem is this: Car is not fast enough. It does 0-60 in just under 7 seconds. I had a few Porsches and the last one I had (964) was considerably faster in acceleration. Today I drove a friends 993 and it is like night and day. My car is simply missing the "kick". Well up in speed it does 170mph without problems but as I said, it has very bad acceleration and its not very responsive at all.
This far from what I have gained from my search it can be the varioram system that doesnt work properly or the dual distributor belt (these 2 seems to be affordable to fix but I might be wrong) . I checked in the engine and saw some sparks in one of the distributors (cant be right I guess).
Have anyone here had similar problems or do you have any ideas what else the problem could be? If you post old threads that can be useful I appreciate that to.
Best regards,
Balazs
PS The car is a 993 C2 from 1996 with 104K miles.
Best regards,
Balazs
RL Technical Advisor
Hi,
There are several things that can affect power output and these should all be thoroughly checked out. The VERY first thing to do is a leakdown to ensure that the engine is healthy.
After that, I would:
1) Make sure the resonance flap is working
2) Make sure the Varioram stacks are functioning
3) Make sure the distributor drive belt has not slipped or is broken
4) Check cam timing since Porsche didn't always do a precise job at the factory and the chains do stretch over time.
High milage - could also be a bad cat and/or dirty valves and intake system. Either one side or both sides of the cat could be partially clogged. A good mechanic with an IR handheld thermometer should be able to help. Also a good engine top end flush with SeaFoam thru the vacum system will help too. I had a similar problem that a replacement cat and SeaFoam fixed totally.
Hi again,
I changed the distrbutors, the belt (was broken) and the airfilter (was complitly blocked) but still I dont have the power.... Also the varioram was tested for vakum leaks but everything is at it should be....Will go and dyno the car its no way I have the full 286hp. I am also thinking to replace the cats with bypass pipes but not sure if it is worth it. Regarding the valves and the intake system I guess the engine has to come out, sounds like a big project but if I dont find the problem I will have it done. Any further input or ideas are very welcome.
All the best,
Balazs
All the best,
Balazs
But before that, I'd verify the health of the engine. Depending on how long you drove the car with a broken distributor belt (and where the distributor rotor came to rest) you could have seriously damaged your engine. Twin-plug motors don't like running in single plug mode for long.
I will take the car to the local Porsche dealer but I am worried its going to be very expensive (they charge over 4000 usd just to change a clutch....) Updates will follow....
I am changing all the ignition cables, rotors and plugs this weekend. Have not had time to drive or fix it but I went to a local Porsche center and I have very bad ignition on cylinder 4 5 and 6. I had the car HP measured today and it was worse then I thought.... I have 204 hp instead of 280plus... The torque wasnt impressive either 265nm..... So much for route 66 motors.... :-(
Tell us where you are and I am sure someone will chime in with local independent mechanic recommendations. Dealers are more focused on newer models. And expensive.
Thanks for the answers, I am now changing cats, lamdas and cleaning the injectors.... After the change of all cables, sparkplugs, distributors my hp went to 247 hp and the torque also went up. I though it would have been a good idea to post the graph from the latest "testrun".
Have a nice day all,
/B
/B
