FS: CR-220 with 993 Face Plate - SOLD
I have a CR-220 (this
is the cassette version) with a faceplate already converted for the 993; Becker is charging $100 for the swap now. It is in perfect condition. It comes with the security code and a printer version of the on line manual.
For a Fellow Rennlist brother.... $160. If you're in Los Angeles I'll even install it for you. This unit can operate an iPod. There are other threads that can give you direction for the pieces you need.
Oh, shipping.... that's free
I have not hooked up the iPod on the Traffic Pro. Reading the links it works the same on the Traffic Pro as the CDR-220 and CR-220. The only difference is the way you activate the accessory function.
As far as Bluetooth.. no way. We're dealing with late 1990's technology here
Available.....
I have two others CR-220 's too. A CR-220 with a CDR-220 converted 993 faceplate -$160
The other is a stock CR-220 - $70.
1 Post
I will take the CDR-220 converted for 993 for $160 in your latest post if you still have it. I sent you an email also.
Clarification: it is CDR-220, right? in the same paragraph it said you have "two other CR-220s" then you said "one is a CDR-220 converted....$160"
Chuck,
