Another Pss10 question.
If I install Pss10s on my 1995 c2 and only lower the car by about 1 to 1-1/2 inches, will I still need new droplinks? Can't I use my stock ones? If not: why??? Is it a length, strength or clearance issue?
I am planning on keeping my stock sway bars for now.
Cheers,
Cheers,
RL Technical Advisor
Johan,
Your front swaybar setup will be fine, regardless of ride height but you might need RS droplinks on the rear depending on final ride height.
A 1" drop should not be any problem, but a 1.5" drop will certainly require the curved RS one since the swaybar must be positioned above the lower toe-control links.
