993 C4S rear suspension versus 993 TT rear ??
Hi, I need tol replace my 993 C4S rear suspension (long story), not in an ax.
Anyway, would a 993 TT rear suspension be an exact replacement ? I assume the 993 TT sway bar back there is tougher than the 993 C4S.
Porsche beefed up the control arms in 1996 so that they're all the same for the turbo and non-turbo. You should check the Parts Katalogue PDFs for specifics like part numbers.
My Porsche dealer tech says the rear Side Section Structures (that the rear control arms go to, and the rear axle goes through, are the same for all the 993 models. I would think though the axle is different between the 993 C4S and the 993 TT ?
Thanks again.
Thanks again.
