Bridgestone Potenza RE 71 on 95 993
My rears are worn out, have these RE 71's all around. Came with the car when I bought it 3 years ago. I can still purchase these tires but not sure if I should. Been reading that these tires have a special sealing bead design for a Denloc system. As far as I know I have the stock cup wheels and not sure if these tires should even be on stock 993 wheels. Any body have some insight on this matter?
Weathergirl
If you have RE-71s on, you need four new tires.
The good news is, you can get a set of Bridgestone tires that are three generations newer than the RE-71s, for just a bit more than the cost of two rear Denloc RE-71s: http://www.tirerack.com/tires/tires....=54YR7RE050APP
Thanks for your input RallyJon. Advantages to this tire is the run flat. Also, the fronts are virtually new so I would need just the rears. I guess I need to know a couple of things... can the re 71's actually be mounted on stock wheels and can I determine by looking at the tires a manufacture date. The mounting on stock wheels concerns me because I have read that these tires should only be fitted on Denloc designed wheels. RE 71's are still available to get so mine are not necessarily too old? Looking for a bit more info before I buy...
AIRKULR
AIRKULR
