Calling on all experts on starting issues (not 993 related)
#31
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Robin, this is one downside to a single ended fuel system (no return, regulated in the tank) is that there isnt constant fuel flow to help cool the rail (and keep cooler fuel flowing). I still think its a heat soak issue with the fuel.
Not related, I am back in Ginza now after two days testing in Sendai Japan. Just chillin' in the hotel overlooking a nice view of Ginza at midnight.
![](http://i243.photobucket.com/albums/ff169/rennsport751/IMG_4142.jpg)
#32
I'm going to put on my "old" hat here to recall my bought new '66 912 that developed the same problem after only a few years of ownership. Solved by adding the starter relay trick mentioned above. It was all related to heat soak contributing to high resistance. Suggest you run a test when it occurs by using a freon spray with an extension tube on the nozzle in the direction of the starter (NOT water!) to cool it down. If that allows it to start, then you have a starter going bad as mentioned above.
#33
Lifetime Member
Lifetime Member
Chris, I am jealous, I would trade position with you any day of the week. I love Japan, especially Ginza.
NC TRACRAT - There are no starter issues as the cranking speed of the motor is the same cold or hot.
