Help! Need my garage floor expoxied in Maryland but my painter isn't knowledgeable...
#31
Steve.....my 2 cents says that you shouldn't be too afraid of a painter that is only charging $250 + materials. As stated by so many, you need to make sure that you acid etch everything correctly. Besides that, most/all epoxy coating will look great. I have attached a picture of my floor. Sorry it's not a better pic but just wanted to show you my floor which is your standard Home Depot 'Epoxy Coat" paint. Took me very little time to put down. Your painter can acid etch one day then come back the next day and apply the epoxy. The reason it is so cheap is because it will probably be the easiest paint job he has had in months.
Good Luck.
Good Luck.
I must say though, I do like the look of the Vinyl
#32
I used a U Coat It product on my garage floor about three years ago and it still looks great - sorry no pics available. When my house was built the builder put a sealer on the floor that was not going to work long term. It also possed a problem when preping the floor for paint as the acid could not get to the concrete. I used an orbital buffer with a 36 grit sanding disc from Home Depot to etch the floor as best I could. The stuff I got from U coat it was the basic medium grey and had them send the aluminum oxide for the nonslip quality. The only thing I would have done differently is add the available clear coat. My floor has zero lifting or peeling anywhere. My floor jack with steel wheels has not done anything to the floor. It is not cheap but it does work. Did it myself. Not hard to apply.
www.ucoatit.com
www.ucoatit.com
#33
www.ucoatit.com
www.ucoatit.com
Am I crazy? Possibly.
Tiles? Epoxy? I'm right back at square one, totally confused. I called and left yet another message with my original painter dude that said for the $450 or so he'd epoxy the floor. Waiting to hear back. Will he ever call back? Who knows.
Steve R
#34
I'm not sure which product the person at U Coat It was talking about or what they were charging to prep and apply the finish but I saw $.44 to $1.49 sq/ft. They must be charging an arm and a leg for putting the stuff down. You may be able to get the painter you find to put this down for much less. I don't have my receipt in front of me but I think it was $220 - $250 for materials.
Here is the link I used. Look under " Residential Floors"
http://www.ucoatit.com/pgs/main.htm
#35
You might consider staining concrete with a good sealer. We did mine 3 years ago and its holding up great.
We powerwashed the concrete. Cut it into 24 inch tiles. Washed it again with a power washer. Stained it with the water based stain and let it dry. We then sealed it with the concrete sealer. Next we took some black grout and grouted the lines to make it look like finished tile. Lastly we put another coat of sealer on it. Turned out great and much cheaper than the epoxy.
Just an option.
Jeff
Just an option.
Jeff
Matt
#36
