Startup racket
Over the past few days I have had my old man's 993 at the house detailing it for him. I have noticed, in comparison with mine, that on startup his is much more "solid" feeling and sounds much more firm. Mine has a rather loud racket. It does not sound good to me at all compared to his. The best I can describe the noise I get from mine is almost a knocking sound (but not really internal sounding). His feels "tighter" or strapped down harder as its cranking over, where mine feels "loose", if that makes any bit of sense? After they both bump over they sound exactly the same.
What could I be hearing? Bad motor mount? Fan hitting the shroud? Something rolling around inside my engine?!?![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I'll get a sound clip here shortly if I can.
FWIW, mine feels faster than his![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Both are 95's. His has 73k and mine has 83k. All stock as far as motor stuff other than his K&N air filter.
Bad motor mounts could allow more engine movement, and would probably be more noticeable on startup. It is pretty easy to take the mounts out and inspect them. There have been some previous threads on this, but basically you are looking to see that there isn't a large gap in the lower part of the mount, and that there is no sloshing sound when you shake the mount.
If the cooling fan is hitting, there will be marks on the shroud.
Lifetime Member
Lifetime Member
Not sure if you were referring to the cranking process, or immediate after starting. I recently replaced a starter in a 993 which made a big difference in starting sound. The new starter cranked the motor much more solid and less rattlely.
I don't notice any marks on the fan blades from hitting the shroud.
One other thing I noticed is that I'll get a knocking or clunking sound when I idle at an autocross while waiting to run. Its very intermittent and clunks once or twice then stops, comes back a minute or two later. Sounds like its coming from the transmission area, not the very rear of the car. Its kind of a "CA-CHUNK" sound. I'd guess around the middle of the hump between the back seats from what I can tell with my helmet on. It only happens once the car is pretty warm (a bit past the 2nd temp mark). I try not to let it get hot enough to do this but at the autoX its rather difficult. Its never done it when in normal driving or not at an autoX.
I know its about time for a clutch (actually over-due). What kind of damage is being done by this?
The pedal is pretty hard compared to the other 993 in the garage and it just recently started sqeeking when depressing the pedal.
Lifetime Member
Lifetime Member
If you are not having any difficulty in shifting, then the only damage is to the clutch. Which doesn't matter if you are replacing the flywheel and clutch anyways.
I just get a bit of notchyness when shifting. no grinding or anything unpleasant.
How bad is the stalling issue for LWF on the 95's? I've read so many bad things about it I'm making myself scared. The car is street and autoX'd and soon DE'd. Worth it for the LWF? I see talk of adjusting the ISV to compensate for the stalling.....
