993 Forum 1995-1998
QUES: How do I remove...
Old Apr 6, 2008 | 06:29 PM
95_993's Avatar
95_993
Default QUES: How do I remove...
Any ideas on the best way to remove old mobile phone antenna??
Is this inductive or did the PO put hole in glass?
Suggestions welcome
File Type: jpg
File Type: jpg
Old Apr 6, 2008 | 06:51 PM
Robin 993DX's Avatar
Robin 993DX
Lifetime Member
strong fishing line just pull it right through, and maybe a sharp razor blade to clean up the sticky pad.
Old Apr 6, 2008 | 07:01 PM
95_993's Avatar
95_993
Robin,
Great idea. I didn't want to try wedging a balde underneath for fear of cracking the glass.
Old Apr 6, 2008 | 07:42 PM
Robin 993DX
Lifetime Member
Same method for badge delete too, just skip the razo blade part at the end... A WD-40 should work good to get rid of the left over sticky stuff.
Old Apr 6, 2008 | 10:02 PM
95cab's Avatar
95cab
I did this last night. I used a standard razor blade paint scraper and worked the edges of the outside portion of the antenna. Once I had done that on all four sides, I applied some leverage using the antenna itself and worked the blade further underneath until it released. Very simple. Then did the same from the inside, but it was even easier because I could see where the glue was, and I used the wire as my leverage point. Now, what to do with the wire - I think I'll cut it and tuck it under the dashboard, then go fishing for it later - shouldn't be a problem. Alas - no more antenna (on the windshield since I have a cab). Great deletion.
Old Apr 6, 2008 | 10:04 PM
Black993's Avatar
Black993
Just pick up one of these and you'll be set!
Check out the thread here on the forums for the $2,000 phone center console on ebay for the completed look!
https://rennlist.com/forums/993-forum/421898-phone-center-console.html
Old Apr 7, 2008 | 03:26 AM
H.H.Chinn's Avatar
H.H.Chinn
Applied heat from a heat gun will soften the adhesive enough allowing the monofilament line to pass through like buttah!
Old Apr 7, 2008 | 10:54 PM
95_993's Avatar
95_993
Harlan,
Even better!
