Champion RG5B 19" Wheels Question
After looking through the forums at pictures of your 993's, I found pictures of a 993 Turbo with a set of 19" Champion RG5B wheels. I'm interested in getting a set of them for a 993 4S, however I'm not sure what the full measurements of them are. The car in the pictures below belongs to forum member "Full Boost" but I haven't been able to get in touch with him regarding them. If anyone has info on the width, backspacing, etc. on them it would help out a lot since I really like this look. Also, if anyone has a used set for sale in excellent condition I may be interested, so let me know!
Additionally, will there be any problems running an equivalent setup on the 4S since it's 4WD instead of 2WD?
Thanks!
Thanks!
The issues w/ running any wheel/tire set on an awd 993 is to keep the front and rear tire heights very close to each other
a problem specific to 19s is the overall height of the tire, the taller the tire, the taller the already tall gearing gets. Stock rear tire height is 24.8-25.3", to get a 19 down to that height range you need a 275/30 or 315/25 then you need matching fronts that will fit in the fenders
1) ABS which wants <5% difference
2)AWD viscous center diff which is considerably more stringent in that regard
Why do I feel so left out!
Justin,
Wow - that car is hot!!
I have sent you an email - sorry I didn't reply earlier - I have been out at the track
These will fit your car fine - no issues with fitment, spacing or rubbing.
The different tyres will make a difference tot he overall rolling diameter - but these are truly dependant and change with each company. I personally have never had any issues with ANY tyres....
BTW - these are no longer made by Champion
Simon.
Simon.
