Rear Main Seal Smoke?
Damn, that's what I thought. He said there was smoke on startup but it was fixed. I'm starting to get a bad feeling. How do you get smoke on start-up unless the engine needs work or you over filled the oil?
Seared
Smoke on startup is not abnormal for a 911 - the cylinders lie horizontal so oil can work its way past the rings. My car smoked a little the day I purchased it in '05 (from sitting) and maybe two or three times since. Drive it every once in a while and this should not be a problem. If I take mine out once a week or so, no smoke.
The rear main seal has nothing to do with this.
Andreas
Andreas
Lifetime Member
Lifetime Member
The owner obviously is not a car guy. He is probably confusing the rear main seal with valve cover gasket. As a leaky valve cover gasket will cause smoke while the engine is running.
Lifetime Member
Lifetime Member
Agree that it is confusing: any external oil leaks can find a way to drip onto the heat exchangers/headers to cause general 'smoke'; however, my first thought was that perhaps it was valve guides that were addressed - were the smoke coming out of the pipes.
Lifetime Member
Lifetime Member
Smoke coming out of the tail pipe does not always indicate a bad valve guide. The nature of the flat engine design will sometime cause smoke on start up. The fluids that will find their way to the heat exchanger can be from upper, lower valve cover, power steering reservoir, and gasoline. Rear main seal is all the way in the front of the engine between the transmission.
