Front bumper grille question
Seared
Has anyone replaced the standard black plastic in the front bumper (non-turbo) - without removing the bumper? Can it be removed/replaced through the openings?
Andreas
Andreas
Andreas,
I did the bumper cover R&R when I had my front bumper cover re-sprayed last summer and if I remember correctly, I think you have to remove at least the bottom half of the cover to get to the clips that hold the grill in place.
If I remember correctly, total removal time was about an hour. Replacement was a little longer because of the care necessary to fit the freshly painted cover without scratching it.
Terry
Terry
The key to removal is to push straight out on the tabs from behind the grille. Similarly, installation should be a push straight in from the front of the grille. If you tilt the grille it increases the liklihood of breakage, particularly of the loops.
Terry
Well, let me qualify.
I had the entire black mesh loose behind the grille and reattached it by snapping the tabs into place by hand. I didn't actually pull the loose mesh out from behind the grille. It's flexible so it might be possible but I didn't try it.
