993 Forum 1995-1998
No power to the cigarette lighter...
Old 02-16-2008 | 05:49 PM
NP993's Avatar
NP993
Default No power to the cigarette lighter...
So the other day I finally bought one of those fancy in-car GPS units, a nice Garmin model that I found on sale at Best Buy. Plugged it in, drove around for a bit, everything is cool, I'm really digging having GPS, fun times, etc.
Then I hit some potholes and the power cord that plugs into the cigarette lighter jiggled loose, causing the GPS to switch on and off. After this happened a few times, the little red light on the plug-in went out, and it was apparent that there was no more current flowing from the cigarette lighter plug-in. I went home and used my V1 to test -- also no joy. I checked the fuse, and it's fine. No other systems are affected.
Any ideas on what could have gone wrong, and how to fix it?
Old 02-16-2008 | 06:04 PM
Butzi's Avatar
Butzi
This is the case with all cigarette lighter adapters I've used with our 993s... Did you jiggle it around a little?
I believe it is a matter of hole size (a different standard) than newer ones. It is not a faulty lighter (at least in mine). Perhaps there is a "sleeve" that would make it stick in there better.
Old 02-16-2008 | 06:20 PM
NP993's Avatar
NP993
I've done all kinds of jiggling; the fit of the GPS plug wasn't super-tight, but it wasn't that loose either. I'm getting nothing from the cigarette plug -- the cigarette lighter doesn't work any more, and neither does the V1 or the GPS.
Old 02-16-2008 | 06:25 PM
993C4Smontreal's Avatar
993C4Smontreal
point a flash light in to the hole, and use an insulated screw driver ( or anything plastic and thin) to pry the 2 tabs (very flimsy and easy to manipulate) inside a little towarsd the center. They might be pressed flush against the sides and are not getting a good connection.
THAT WORKED FOR ME.....AND THE FUSE WAS BURNT
Old 02-17-2008 | 01:05 AM
DocTock993's Avatar
DocTock993
Or, like mine, the cold solder joints for the wires going to the lighter broke off.
Quick Reply: No power to the cigarette lighter...
