Distributor Installation
I had big dizzy issues and ended up swapping the inners into a new housing during the rebuild THANK YOU CHRIS WALROD who did an awesome job.
I had the motor at TDC, I beleive, when I removed the dizzy. The notch in the pulley was on top and the rotors were pointing just a tiny bit clockwise from #1. The new housing doen's have the markings where the rotors were pointing so I'm trying to get it lined up. Other than eyeballing at the #1 wires or using trial and error is there a more exact way?
Thanks, John
Thanks, John
I got it. Notch on the housing right where the rotor should point on install. Fired right up, although there are a few crackles on decel so I need to check the plug wire, but shoul dbe good shortly.
