993 Forum 1995-1998
Carpet removal, the easy way!
Old 01-27-2008 | 06:12 PM
leeshephard's Avatar
leeshephard
Default Carpet removal, the easy way!
after trying various methods at removing the carpet I was given this tip by David at Southbound Trimmers in the UK....and it is SOOOO easy, no hacking with a knife, no heatgun then burning your hands with molten glue, no little bits of glue stuck to your hands, arms, hair etc....
The secret is to use a steamer! one with a nozzle, and just steam the glue...it comes apart almost by itself with little or no pulling, which saves possible damage to the 10 year old rubber sound deadening.
I removed the whole back section in about 30 mins ish this morning using this method.
just remember to open both doors and sunroof first (unless your lucky enough not to have one) and make sure the car it properly aired and dry after you finnish.
I hope this tip will be as useful to others as it was to me.
cheers
Lee
The following 2 users liked this post by leeshephard:
Enso (11-03-2022), pp000830 (11-04-2022)
Old 01-27-2008 | 08:51 PM
LA964RS's Avatar
LA964RS
F*UCK!......Now you tell me!!!!
Old 01-27-2008 | 08:54 PM
Mark in Baltimore's Avatar
Mark in Baltimore
Are you saying that the hateful adhesive comes off very easily with the steam??
Old 01-27-2008 | 09:01 PM
Gasser's Avatar
Gasser
Where were you about 3 weeks ago...
Old 01-27-2008 | 09:14 PM
axl911's Avatar
axl911
Yeah...where were you about a month ago!!!! I took me days to remove the carpet. The padding came out with the carpet.
Old 01-27-2008 | 09:42 PM
mr_bock's Avatar
mr_bock
Perfect timing!!!!!!!!!!!!! My Body Shop will be taking out my carpeting very soon. This will be a huge help.
Thanks a million!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-27-2008 | 10:17 PM
Garth S's Avatar
Garth S
Great tip! I've stored the salvaged carpet still glued to most of the grey rubber backing from a parts car ... looks like the ugly hide from a bad skinning job on a woolly mammoth. I'll try this to see if a recovery operation can be done
Old 01-28-2008 | 12:08 AM
Raptor's Avatar
Raptor
Is installation of "off the shelf" carpet as easy?
Old 01-28-2008 | 06:48 AM
leeshephard
glad to help guys!
I'm about to embark on it myself, i'll let you know in a week or so! wish me luck...
Old 01-28-2008 | 06:54 AM
leeshephard
also, just to clarify...you MUST use a steamer with a hose and nozzle, so you can direct the steam right at the glue. I found the best method was to pull the carpet gently while directing the steam the carpet and rubber in an up/down motion along the 'join', if you do hit a big blob of glue just blast some steam at it for a while then try to pull it off with your fingers should come of easy.
Old 01-28-2008 | 12:41 PM
Mark in Baltimore
Thanks for the clarification, Lee.
Old 01-28-2008 | 01:07 PM
Flying Finn's Avatar
Flying Finn
King of Cool
I've taken my sound deadening off but have the RS carpet and have been thinking of removing everything, what kind of stemer you used?
Old 01-28-2008 | 05:05 PM
leeshephard
this is similar to the steamer I used:
http://www.amazon.co.uk/Vax-V-081-Co...sbs_kh_title_8
Old 01-28-2008 | 05:26 PM
Flying Finn
King of Cool
Thanks.
Old 10-28-2008 | 09:49 AM
ninjabones's Avatar
ninjabones
I have to say that this steamer idea did not pan out as well as planned. The foam comes off fine, but the adhesive still stays behind. I actually found that it was easier to use a heat gun and a plastic scraper. The heat gun does leave a bit more foam behind, but that is easy to remove. It's all the adhesive that is the PITA. The steamer just got everything in the cabin soaking wet.
Still trying to find the best technique to remove the gobs of adhesive everywhere. So far, it appears that spraying generous amounts of "goo gone" (sears) followed by a blast with a heat gune works the best to soften up / liquify the adhesive. You can mop it up with a dry rag while it's still hot. However, it still took me over an hour to do one small section on the rear deck. Also tried "goof off" and denatured alcohol.
Any collective wisdom on how to get this adhesive off easier?
Quick Reply: Carpet removal, the easy way!
