PLEASE HELP ME DIAGNOSE THIS PROBLEM
I will try to describe this noise the best that I can. It is a buzzing noise that is coming from the engine were the the fan is. If I put my hand on the fan housing I feel a vibration. I guess the best way to describe the noise is a noisy electric fuel pump that goes up and down with the rev of the engine. Thanks for any info.
Lifetime Member
Lifetime Member
Could be the bearings on the alternator is going. One way to test is to take the belts off and free sping the alternator with your hand and see if it spins freely or make any noise.
It is louder when cold, If I remove the belts can tell the difference between the bad fan hub bearing or the alternator? I just replaced the belt tension sensor.
