CR-1 To Amp Radio Connector Needed
Greetings all. After a butcher job by a local sound company on a converstion from the CR-1 radio to the newer CDR-220, I am in need of the rectangular connector that goes on the amp under the passenger's seat. I believe the amp was only present on the Hi-Fi option. I need at least 6 inches of wire off the connector to make the hack job right. Been looking for a while. Am I dreaming to think I will find one? Thanks.
993.645.413.00 regards
I greatly appreciate your trouble Geolab but the connector part number you provided is the short cable between the CR-1 and amp that has round ends. I need the connector that connects to the amp under the passenger seat, that is rectangular in dimensions, and connects the speakers to the amp. It is at least at 20 pin connector. I mistakenly wrote last night it was the connector from the CR-1 to the amp. Sorry for your trouble.
Here is a photo of the connector I am in need of to repair my factory sterio after the hack job. Only exception is I need more wire coming out of the connnector. About 6 inches would be great. I have attached a link where the photo can be viewed in a larger format. Thanks.
http://i56.photobucket.com/albums/g1...mp/AmpPlug.jpg
