What "extras" are needed for C4S susp. upgrade?
Getting ready to put Bilstein HD shocks and H&R springs on a 1996 C4S. Are there any other components that I need that pertain specifically to the all wheel drive 993...i.e. extra locking collars, drop links, bushings, etc. to make the swap?
The only 'extra' I added were the two lock rings to the undersides of the rear drop link mounts: your fresh HD's will be supplied with the correct shorter drop links.
If the sway bar rubber mounts are OK, move on
.... otherwise, it is a good opportunity to refresh, especially the PITA fronts. The rears can be done anytime ... blindfolded.
