993 Forum 1995-1998
another relay location
Old Dec 20, 2007 | 02:14 PM
stace's Avatar
stace
Default another relay location
since we are on the subject of relays. I get an intermittent ABS warning light and a code reading shows ABS relay fault. the relay is not expensive but I'm not sure where its located. I suspect the black plastic case in the front boot next to the spare tire on the passenger side wall?
can anyone confirm the proper location and id of the relay?
as always thanks in advance for the help - Rennlist is the best!!!
Old Dec 20, 2007 | 05:06 PM
trickydisco's Avatar
trickydisco
You suspect correctly.
That is, indeed, the location of the ABS relay, but there are
a few of them:
R65 is for the ABS motor driven pump
R66 is for the hydraulic brake boost pump
R68 is for the ABS valves.
Hope this helps.
Old Dec 21, 2007 | 01:06 PM
stace's Avatar
stace
great. thanks very much!!!! that is very helpful
