RS Seats On Ebay...Speedster?...
As others have stated, you're butt will probably fit fine; however, if you plan to use a 6-point harness for the track, the holes on the pole position seats (which look to be at the same height as these), may be a bit low for your shoulders. You can also see that the slots for the harness are very small and do not allow a lot of adjustability for the position of the shoulder strap. This could present a problem in terms of the angle of the straps cranking down on your shoulders in case of an accident. If, however, you do not plan to use on the track, then the seats should be fine.
