DIY QUESTION
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Also on the pressure hose near the banjo fitting, there is two small tangs that keep the line clocked while you're tightening down the banjo bolt to the pump output. Make sure you get those tangs aligned properly. You'll see what I a referring to once you get to that point.
Thanx to all you guys!! I got the part from Pelican and it's done! and on to the next question..
I took her out and she run's great! no leaks, thanx again mikej & bobbyt and as always chris..
Notch
Notch
