I won my nine DE's with wheels made of paper mache and carbon fiber strands. Light and strong but annoyingly weak in the rain.
But seriously, I thought part of the theory behind the weight of the Ruf "anchors" was that a gyroscopic effect gave straight line stability at very high speeds. (probably the same speeds at which the aerodynamic effect of the 993 engine tray comes into play )
Another important and frequently overlooked element is product liability. Car manufacturers (Porsche and RUF) would naturally opt for the stronger and therefore heavier wheel to minimise that risk. In contrast, after-market wheel manufacturers don’t bear this burden to the same extent: their wheels are not “manufacturer approved” yet the buyer has chosen them. Therefore it’s the buyer’s risk. Also, most are foreign based and more difficult to sue. It’s no coincidence that wheel weights - and car weights in general - have increased significantly since the ‘80s.
Wouldn't an extra 5lbs on each rear wheel be the equivalent of losing 10-20 HP?
I think it's more a relative thing: I bet the lightweight flywheel guys can feel it much more.
Personally, I didn't detect the approx 2lb difference per wheel+tire going from summers to snows on the 993. On my old STI (which also had a light flywheel unlike the 993), my summers weighed about 7lbs per wheel+tire more than snows, and I would literally stall a couple of times every spring before I got used to feeding in a bit more power when engaging the clutch. Anyone--numb butt or not--could have felt that difference.
There is a big difference between what is theotretical, what is perceptible and what is measureable.
Most of the claims of perceptible difference in weight of under 10#s turn out to be caused by tire height differences, even small tire height differences are easily perceived.
