993 & Bishoff to Gillet Mufflers
I am stoked after my one day at Rennsport Reunion III. I guess one day is better than none. Lots of great people and the track was open for all groups of cars. I have Bishoff mufflers on my 993 and just purchased Gillet Motorsound mufflers. I currently have Gillet Motorsound tips that fit with the existing donuts. What will I need to marry the Gillet Motorsound mufflers with the exhaust pipes further back? Another set of donuts perhaps? Thanks all.
no, thats not right, I've seen some real muts that Porsche put out on the late cars. One was really weird and was a complete mix of parts ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Maybe it was me building all my pipes with the doughnut built in that has me somewhat confused
it has been a LONG w/e though and I'm tired.......no excuse I know
Okay I'll stop now
disclosure........LISTEN TO NOTHING I'VE SAID QUASR.
Good night!
Okay I'll stop now
Good night!
So just to summarize, you can swap Bischoff's and Gillet's freely on the cat side (in other words, the cat connections are the same). The only compatability issue may be with the tips, correct????
Maybe you should post a photo of your Gillette mufflers - easy to assess the issue then. But if your Gillette mufflers Bischoff style cat inlets, you should be good to go for hooking them up to your Bischoff cat.
My car is a 95' and the cat is Bischoff-only. It has donuts just like my mufflers. You could try to plug your Gillette mufflers into it, but you may have a problem with clamping it up???
Gillet and Bischoff mufflers mount to the cat the same way...........They both use the doughnut gasket on the CAT side. On the exhaust tip side, Bischoffs use the same doughnuts, but Gillets have the doughnuts built-in. Pretty simple. Look at the pics I posted, the circled part is the "tip" side. The other side (not circled) is the "cat side".
Cat side=same,
Tip side, Bischoff=needs doughnut, Gillet=doughnut built- in.
Switching from Bischoff muffler to Gillet=no doughnut needed on TIP side.
Switching from Gillet to Bischoff=need to buy doughnuts for TIP side.
Paolo1 (09-11-2022)
Marlon,
Cat side=same,
Cat side=same,
Kinda funny, i was just thinking about how badly I wanted to do exhaust after being at Rennsport all weekend! My car was not nearly loud enough going through the tunnels.
I'd say just skip the motorsound and go loud!
Bischof on left Gillette on right
![](http://forums.pelicanparts.com/uploads11/04_14_2006_+0061193957616.jpg)
Doughnuts used by Bischof, discard if using Gilette because Gillettes have them intgral to the pipe but only on the outlets
![](http://forums.pelicanparts.com/uploads11/04_14_993_1193957704.jpg)
The head connections are the same on all
the header/cat connection is different. Gillette cat(or cat bypass) must be used w/ Gillette headers, Bischof cat(or cat bypass) must be used w/ Biscoh headers.
The Mufflers and tips mat be used interchangeably.
