Glue to reattach driver's side mirror?
You mean the mirror itself off the holding bracket?? If so - I used a 3M adhesive (I can look at the part # - as I think I still have the old tube?) If you mean the whole mirror assy - as attached to the door panel - nope - no adhesive!!!
Best to ya'
JD
Best to ya'
JD
Huh?
I'm "just me" - that's all there is, was - or will ever be...!! I love my P'cars!! (Well, Jen's 964 might be a bit daunting when I pull/rebuild the engine - but - I'll save that when I get that engine out and on the floor...![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
OK - are you set - or do you want me to try to find the tube of 3M that I used???
Best to ya'!
JD
Best to ya'!
JD
For the MOUNT itself, there's a little black cap that covers a small metric allen bolt that can be tightened a little to firm up the mount itself. Use a pocket knife blade tip to pop out the black cap and be very careful you do it over a garage floor since you will never find it if it lands in the grass!!!!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
