Calling Wheel Experts, TPMS questions
I am in the process of getting a set of used Speedlines (pics below) for my Cayman. I called the dealer today to ask about mounting tires and switching the TPMS sensors over to the new wheels (mine is a 2007 so TPMS is mandatory for the car). They told me that not all wheels are born equal as far as TPMS goes. Older wheels may not have the cavity by the valve stem in place to receive the TPMS sensors. What a rude awakening that was.
I called Tire Rack and they confirmed that they only carry wheels that are TPMS compatible, and true there are wheels out there, older ones especially, that are not TPMS compatible.
I see that I have these options:
(1) Ditch the used Speedlines and keep the OEM wheels.
(2) Buy new TPMS compatible wheels, but I just love the look of these Speedlines.
(3) Keep the Speedlines, and forget about TPMS (if these indeed are not compatible), and live with the warning lights.
(4) See if there are wheel experts who can make these Speedlines TPMS compatible.
So if anyone has any suggestions on this TPMS mess, please educate me. I really hate these newer modern cars. Change the wheels messes with the TPMS. Change the seats messes with the seat-mount side air-bags. Life with these newer cars is so much more complicated than with the plain 993.
Any help here is appreciated.
CP
That's one of my options and frankly that's most likely what I'd do. I use gages for pressure checks anyways. I also keep my cars forever, so I don't worry about resale and 'what'll the next guy say kind of issues'. Can't pass up the classic look of the Speedlines for a lousy PTMS system, me think.
Glad to see you have a set of Speedline on your 993, 18" I bet.
CP
Rennlist Small
Business Sponsor
It may be that wheels not able to accept these sensors need just a quick and simple spot face operation on the inside surface of the wheel, local to the tire stem bore.
This is exactly why I am calling on wheel experts.
Can you judge what it takes: "quick and simple spot face operation on the inside surface of the wheel", or you know some other wheel experts (ala wheelenhancement etc.) who can tell you. Any help in this area is much appreciated.
Thanks.
CP
Here is a LINK to The Tire Racks TPMS page.
I am not particularly interested in TPMS per se. My main goal is to avoid the annoying dash light that comes with loosing the TPMS syatem with the Speedline wheels.
Going with other TPMS may not eliminate the dash warning lights, so that does me no good.
CP
The main difference is that your DP Motorsports wheels have thicker spokes, and thicker rims, thus the vent openings are a little smaller than the Speedlines. Hides the brakes a little more.
They are very close in basic design though. Are yours chrome, or just high-polish? Looks beautiful on Iris Blue Metallic, no doubt.
CP
How about a small canister with a screw on lid
Drill a hole in the lid
Insert a valve stem (metal screw in type would be safest)
Throw the four sensors into it
Close it up and pressurize it to 30psi
Throw it in the trunk indefinitely
Not sure if the computer receives all data from a central point or not but this seems plausible.
Rennlist Small
Business Sponsor
