?resistors for blower delete?
anyone got a current source for these?
Excuse my nubieness, if you delete the blower why do you need a resistor? We are talking about the oil fan?
blower delete
http://forums.pelicanparts.com/uploa...1173803087.jpg the oil cooler and AC condenser both have fans, but you don't want to delete them. |
Oh, I like that, what's the CF pipe cost? How much weight did it remove? Down sides?
My first thought was you were doing a constant on for the oil cooler fan, or removing the heater fan. |
Hmm.. I did the mod.. I installed the resistors, I gotta search for the values.. Let me see-
Coleman. |
Originally Posted by Stealth 993
(Post 4710473)
My first thought was you were doing a constant on for the oil cooler fan, or removing the heater fan. Dual coolers, no heat issues http://forums.pelicanparts.com/uploa...1193150699.jpg |
Originally Posted by Coleman
(Post 4710502)
Coleman. & 18K ohm 2 watt resistor I just need a source |
Ah yes.. So, to fool the system, two resistors were used - one for the motor and one for the temperature sensor. (Thanks to Adrian Streather and Chris Duffey who provided guidance on determining the correct wattages). For the motor, a 51 ohm 15 watt wirewound resistor (#1 in picture below) works, and it does get warm to the touch when the heat is on. The temperature sensor is the wire going into the top of your existing air pipe. This senses the temperature, and sends the fan into overdrive if the airflow gets too warm. An 18K ohm 2 watt resistor (#2 in picture) is used, which tells the computer it's around 40 degrees F. The last resistor (#3 in picture) is the long one with the curly metal wire that's stuck in the side of the original air pipe. It's there to break the electrical circuit should the motor develop a short, so, for simplicity, it was left alone.
http://www.porsche964.co.uk/technical/noheater.htm Coleman. |
Oh, I understand.. Sorry Bill..
Try Mouser.com Coleman. |
Bill - I found them at a local electronics shop. I might be able to stop by in the next week or so if you need.
Originally Posted by Don Plumley
(Post 4711097)
Just got a lead on a local source
Bill, thanks! This looks like something that I want to do. Both the extra cooler & the blower delete.
Where can the CF pipe be sourced from? |
FYI,
I don't have the blower but didn't put any resistors. Just zip tied everything to the side of the engine compartment. No issues. I also used to have c/f pipe put removed that too since with that some of the cooling air from the fan is "wasted" thorugh that. |
Originally Posted by Flying Finn
(Post 4712254)
FYI,
I don't have the blower but didn't put any resistors. Just zip tied everything to the side of the engine compartment. No issues. I also used to have c/f pipe put removed that too since with that some of the cooling air from the fan is "wasted" thorugh that. I've been chasing down a code the is thrown at every start. Using my "hammer" emulator, I can read and clear them. The pesky code is for the rear blower which is not there. heat & AC do work fine I just assumed that the resistors are shot |
