Wipers rest too high
My C4 wipers seem to rest a little too high on the windshield.
I've read the archive posts about switching your wiper position to the passenger side, but is there a way to adjust your wipers so that they rest lower on the driver's side? The top blade needs to be lowered by a good inch or so.
I like the intermittent feature, so pulling the relay and manually stopping the blades on the passenger side is not all that appealing.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Just be careful, when you are using an open ended spanner (there's one in your toolkit that fits this 'nut' perfectly) that the 'other end' of the spanner doesn't rub/scrape against the paintwork as you 'swing it around'.
Also, make sure - when you re-seat both wipers into the lower position - that when you put the bolt back on - that the plastic cover is seated properly. You can test this by lifting up each wiper, in turn, to see if the lower-arm/hinge 'clears' the lip of each cover. Don't be too surprised if one 'boings away' -- if it does - just re-seat it and test again. If they "don't boing away" they're seated properly.
Gerry
What HE said (coz I've done this many times).
Gerry
Gerry
