Anti Lock brake light came on today after getting new tires
One can change the wheel width from 9" to 11" and not make any significant impact on overall tire diameter (<0.5%) ... that's why I initially stated that wheel width is a non issue re the ABS.
The tire overall diameter directly influences the frequency picked up by the ABS sensor(s) ..... and there is ~5% variance in the two tires in question.
GARTH THANKS WHAT ABUT THIS
[QUOTE=Garth S;4578561]One can change the wheel width from 9" to 11" and not make any significant impact on overall tire diameter (<0.5%) ... that's why I initially stated that wheel width is a non issue re the ABS.
iToyo has a chart that shows rev's per miles my original tires were
Original
Fronts 235 40 17's = 852
Rears 255 40 17's = 828
Difference of = 24
Now
Rears 275 40 17's = 812
Difference of = 40
If i switch my fronts to
Fronts 235 45 17's = 834
Difference of = 22
Seems to put me back to an even less difference that my original set up , seems that should work , only question is will the turn in be harmed by going to a 45 versus a 40 aspect/profile ??
Dennis
Original
Difference of = 24
Now
Difference of = 40
Difference of = 22
Dennis
If you are worried about turn in with a taller profile front tyre, focus on the rear setup and replace with 275/35 - it will achieve the same effect of reducing the variation in revs/mile to 6 (about 0.7% - perfect).
Trevor good idea but ....
Thanks but .......seems the only option is to go to 35 profile in front
Dennis
I'm sure you meant "go to 45 profile in front" and if so I think you're probably right (I don't think anybody makes a 275/35/17 but Toyo certainly make a 235/45/17).
Friend with a 95 c2 coupe had 275's and just the concept of wider must be grippier/ better ........now unless want to loose the abs with track tires my next set of frronts will be 235 45 17;'s versus the 235 40 17's and according t the toyo calucations i will be nearer to th original diferential in wheel speed for both front and rears
Dennis
Dennis
Dennis,
Did you double check the abs sensors on the hub to make sure they haven't been damaged or come loose?
I have run tires up to an 1" difference in diameter with no ABS issues.
Hi Greg
thanks
Dennis
Not so good on the sidewalls :(
Your front to rear rolling radius delta is 4.91%. This may be too much for the ABS computer to handle. I have an EXCEL spread sheet I will send you where you can plug in the width of the tire in mm (235), the sidewall hight as a percentage of tread with expressed in %age (40) and wheel diameter (17"). Once this is done, the front to rear rolling radius delta in %age appears, as if by magic!!!
send an e-mail to mfschacht@gmail.com and I'll send the spread sheet to you. I am certain the problem is...the front tires are too short at 40%. You may have to go to 45%.
No worries, there are plenty of cars that use a 235/40/17 tire...GTIs, some BMW cars...you can always sell them.
Don't tell anyone, but I recently bought a pair of 235/40 RA-1 tires by mistake...I sold them to a GTI guy and replaced them with the correct 235/45/17 fronts to go with my 275/40/17 rears. This equates to a 1.3% delta front to rear, no problem for the 993 ABS.
Martin ,thanks for he info
Original
Difference of = 24
Now
Difference of = 40
Difference of = 22
thanks for confirming it, looks like i will buy a set of 45''s when my 40's weaqr out ,maybe one more track session !!!!
Dennis
