Two-tone seats with piping
Are these stock? I've never seen anything like this before in a 993.
I'm thinking of getting back into a 911 after a foolish and expensive detour into BMW M cars. The local dealer has a white '95 C4 on the lot, but the price seems really high ($37k) with 55k miles on it. These seats look like they've been re-covered, which makes the price seem even more out of line. It would look great with creator8's red volks, if I could talk them down closer to $30k.
Save your money for other mods - just use a good quality leather dye on the seat inserts and you will be back into the black....
Black is a good option because it is a less 'uncommon' (more 'common')interior option - so you can get stuff for it more readily. Mine is cashmere (tan) - close second, but sometimes hard to get stuff. My drivers seat foam was pretty well blown out too. The cost to re-foam versus the used ones was too close.
I figured they were recovered - the leather (or *shudder* vinyl) is bunched a bit around the hinge.
What do you figure this car would be worth if everything else checked out?
If everything checks out with a Pre-Purchase Inspection, PPI, then between $30 - $32K would be market. Good luck
Do not know if they are still available, but it gives you an idea.
Good luck
Ron
http://forums.pelicanparts.com/showthread.php?t=364582
Good luck
Ron
