993 Forum 1995-1998
How do I remove Center Console
Old Sep 2, 2007 | 03:29 PM
slvr993's Avatar
slvr993
Default How do I remove Center Console
I'm in the middle of ripping out my interior and I need to pull the center console. I'm sure it's simple, but it's not obvbious. The only screw I can find is at the very rear of the unit in the tiny change holder thingy.
Maybe I just lost tooo many brain cells from all the adhesive remover.
Jeff
Old Sep 2, 2007 | 03:48 PM
David in LA's Avatar
David in LA
You also need to remove the 2 switch plates at the front of the console as well as the handbrake tray...once your remove these you can access additional screws that hold down the console.
