Lagging Engine Question
I've got a 98 C2S w/ about 33,000 miles on it. Just recently I"ve had this loss of power when I'm in gear. The rpm's will be running at about 4000, then it will lose power and drop to about 3000 but then run back up to 4000 after a second or two. I was told it may be the clutch giving out, but seeing that I have such low miles, I thought I'd get a second opinion and commandier all your suggestions.
If it is a clutch problem, what's the going rate to fix something like that
Thanks in Advance
rjc993
Thanks in Advance
rjc993
P-car Lagging
Sounds like a clogged fuel filter to me. Give that a try. Instructions are here:
http://p-car.com/diy/fuelfilter/
