OBD2 Port Not Functioning
Hey guys,
After seeing DHicks's emission post (congrats btw), it just reminded me my date is coming up. The OBD2 on my car does not appear to be functioning. When I brought my car in for NYS inspection last year, the shop was not able to connect the computer via OBD2 and said the port does not work. I was still able to get it passed
, but that's another story. Should I go to my Indy or is the OBD2 somehow "warrantied"??
Or perhaps this is a blessing in disguise??
If the readiness codes are not reset, your car will not be able to communicate with the emission station' computer. When this happened to me last week, at least they were able to tell me which codes were not reset, so there must have been some communication. You should get one of those cheap code readers and see for yourself and then follow the dreaded reset procedure.
Thanks.
Hey guys,
Or perhaps this is a blessing in disguise??![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I think there is more to it than that but I believe that's the basics. There is an older post that describes it in detail if you wish to search for it.
Be aware the OBDII system works a little differently on the 993 than most other cars. Most cars will communicate when the key is just turned on (not running) and the shop can read it then. On the 993 the car has to be running for it to communicate with the external reader.
Thanks again.
I've found it's just easier to start the car when I have mine emissions checked though.
Arrwin,
The immobilizer must be OFF for the OBD-ii to successfully talk to the scanner/emissions test equipment. That means, of course, if the car has been sitting for a while (engine off) then the guyz need to 'blip' the FOB so that the immobilizer light goes OFF -- and THEN connect their scanner gear.
OUR cars use the ISO-9141-2 protocol -- which is a bit esoteric (being predominantly European) -- and most 'mundane' scanners have problems 'communicating'. (Most American cars use the JWMxxx protocol) which is 'easy'.
If I meet u on Sunday - for the Sunday run -- I'll bring my code-scanner with me and we can do an OBD-ii looksee. Having done this OBD-ii fandango (on my own car(s)) more times than I've had hot dinners -- :-) -- I'll have an answer for you in a jiffy.
As a matter of fact, if any o' y'all want your 'readiness stuff checked' or if you wanna find out if there are any (hidden!) 'PENDING' codes stored (that could soon manifest themselves as REAL CELs) then I've no problem - that day - schlepping myself and my code scanner around other cars too.
I'll be easy to spot -- I'll be the one with the Iris Blue 993, cheesy grin and funny Irish accent.
Gerry
Gerry
Thanks for the gratitious offer! Can you print an inspection sticker too?! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Arrwin,
Gerry
Gerry
