pic? old style holder (metal) or newer (plastic)? mine was the older version which i just pulled the plastic nibs out w/ needle nose pliers. newer style pop out like legos.
They should just pull out. Basically, the screw just spreads the two tabs, similar to a plastic wall plug. I decided to take mine off because they were always coming loose - I could pull the frame holder off even with the screws still in there.
If you're really concerned, maybe spray some WD-40 back there.
