Removing A/C Vent???
I have a problem with the passenger side A/C vent on my '96 and would like to remove it. However, it is unclear to me how this is done! I removed the cover on right side of the dash - that did not seem to be involved. I also searched the factory manuals but could not find the section on removing this.
Anyone tackled this yet?
If you are talking about the plastic air vents they just pull out, they are held in with spring tab mechanisms, top and bottom. I think you can see the tabs just sticking down if you look into the vents.
I had to remove the driver's side vent when running the line to my radar detector. There's a DIY somewhere in the archives...presumably, the passenger side works similarly...
