Help identifying chip
Seared
My '95 came with a small plastic container with a chip inside as well as a set of instructions from Weltmeister regarding their performance chip. While I am fairly certain the Weltmeister chip is actually installed in the car, the chip I have is not labled with anything Porsche-specific. It has a series of numbers on top: 1 367 358 164. Is it the original, or the aftermarket?
I've already removed the seat and would like to reinstall the stock chip in an effort to eliminate some hot weather pinging.
![](http://img.photobucket.com/albums/v452/aowalter/Porsche%20parts/Chip.jpg)
Andreas
Andreas
Seared
Steve,
Thank you. If I can find the time tomorrow, I'll reinstall the stock chip and see if I can feel a difference. I presume the battery should be disconnected before unplugging the ECU?
Andreas
Andreas
RL Technical Advisor
Originally Posted by AOW162435
Steve,
So there is no issue unplugging the ECU in order to open the case on the bench?
Andreas
Andreas
Seared
Originally Posted by Steve Weiner-Rennsport Systems
Nossir,...With the key off, remove the ECU, open the cover, momentarily ground yourself to dissipate any static charges, and replace the chip. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Andreas
Seared
I finally found the time to re-install the factory chip tonight. After closing the ECU case (Labled "Motronic 261.203.163 / 993.618.123.02") and plugging everything back in, I fired her up. Oddly, I found that the idle seemed smoother.... I let the car idle for a while and then took a gentle drive - all seems well. Hopefully I can take it for a proper whirl tomorrow and see if the occasional pinging is gone.
With the seat out, I was able to apprehend $0.29 worth of coins that made their presence known during vigorous cornerning. I also unbolted the mounting plate for the ECU in order to retreive a few crumbs and an old band-aid.
All's well for now.
Andreas
All's well for now.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Andreas
I think those Weltmeister chips run a buttload of advance timing, no wonder it's running smoother. Or maybe it was the two Cheetos and the bandaid stuck to the ECU.
Seared
Originally Posted by black ice
I think those Weltmeister chips run a buttload of advance timing, no wonder it's running smoother. Or maybe it was the two Cheetos and the bandaid stuck to the ECU. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Apart from the coins and such, it was like new under the seat.
Andreas
Andreas - interested in your comments once you get to open her up a bit.
I have been listening intently for the slightest ping and (knock) on wood, NOTHING....
Take a look at the # of posts.... spooky>>>>>
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Andreas, I too have a Weltmeister chip that came with the car. I removed it & put the stock chip in & the car ran much smoother. I have since invested in a Rennsport Chip from Steve which I love (it's nice having him 20 minutes away). The Welmeister chip is currently sitting in it's case in the drawer.
Seared
Brian,
That's good to hear. I took the car out for a vigorous run today - no pinging. I drove it under the same conditions during which I've noticed pinging in the past. It generally seems to run smoother. Whether or not it's a mental thing because I've changed something, I still feel better having the original chip back in there. The car seems just as powerful as before.
I'll put the Weltmeister chip on Ebay.
Andreas
Andreas
Seared
Steve,
I was simply concerned with engine damage. I could care less about the potential for 10 more hp. This car is with me for the long haul.
Andreas
Andreas
