My 95 wont rev over about 5400....Help!!
Welcome Mark -
I can't help you out with this specific poroblem, but I'l be sure to hit redline in my '95 on the way home tonight. Patially out of curiosity, and partially out of fun..
Anyway, welcome to the 'other' forum that I hang out on. You'll generally find folks in this group much more mature and helpful. Always very helpful and supportive - makes for great reading and assistance with problem. Its nice to not have to surf through the juvenile angst of bimmerforums for a helping hand.
Welcome! and good luck ironing out this gremlin. I'm sure it will be fine. Caps, plugs, and rotors are great place to start, along with an air and fuel filter.
Aaron
Aaron
Have you checked the distributor drive belt? Take off the second (left) distributor cap, if the rotor spins freely then the belt is broken.
One other thing, have you checked your gas pedal to see if you are getting full throttle? Either a misadjusted pedal or something got wedged.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Like mentioned above, have a look at the dizzy caps for carbon tracking and replace the fuel filter, unless you are confident it has been replace recently. Almost sounds like a fuel starvation situation since it will rev freely without load, but wont with load.
Congrats on the car, BTW! Nice looking example!!
Thanks Guys!!! Im off to pick up the parts right now. Im hoping to have time to geth them all installed this weekend!!! Thanks again! Mark
PS, I thought the dist drive belt was only a problem on the early unvented 964's?
RL Technical Advisor
Based on experience, I do recommend replacement every 50-60K as thats FAR cheaper than the consequences.
Seared
Mark,
What a beautiful color - congrats!
My first thoughts would be fuel filter and possibly the distributor drive belt.
Is your engine undertray still on? That could certainly factor into the equation.
Andreas
Andreas
It is midnight blue! Also, where did you get the Rennsport chip?
I got the Rennsport chip from Steve Weiner of Rennsport Systems. He posted earlier in this thread, so you can see his contact info. The chip works like a charm, I highly recommend it. Thanks, Steve W.! The chip adds noticeable power to the midrange revs (which I suppose in your case is the high range revs for the moment!). It's an easy DIY to change the chip on a 95. Well, except for cutting the darn security bolts to get to the chip. That took me forever using a drill, dremel, and the entirety of foul vocabulary available to me.
THe rear tray is still on. I will get it off this weekend!! Steve, I will most certainly buy a chip from you as soon as I get the car running better! Please PM me a price. And Twindaddy, I LOVE adventuring green!!! Thanks for all the help guys!!!!!!!
Red Rooster- KS400200,the oldest 964 on Rennlist,unless you know differently ![/QUOTE]
1700 posts as a user... now thats got to be a another record.
Originally Posted by Steve Weiner-Rennsport Systems
The distributor drivebelt issue affects ALL 3.6 motors; the vent kit simply extends their life span.
Preventice maintainence.
