993 RS Roll Cage Question
3rd Gear
Hello. I am in the process of converting my 95 Carrera into a Carrera RS. I have been searching everywhere for a WELD-IN (not bolt in) roll cage that is almost exact to the Supercup cage. Does anyone know who would supply a cage that fits exactly like the one im asking, even knowing I need to cut a section of the dash? Thank you.
I would try to seek out an original 993 Cup and take plenty of photos of the cage, then seek out a cage builder who can replicate it exactly. You will not find that cage for sale as a kit.
Where are you located? There is a cage expert in Akron Ohio who has done it and he is very good...Does many Rolex Grand Am cars...website is www.rollcageguy.com
Standard RS, did not come with a cage. I have an RSCS which came with the factory welded in matter rollcage.
The only difference between the CS cage and that in the car cup car is the single diagonal door bar on the CS, against the double "X" diagonal on the cup...as far as I can tell anyhow having had the 2 cars side by side.
With respect to cutting a section of dash, the down bars go through the air vents,,,hopefully photo attatched.
![](http://i111.photobucket.com/albums/n138/clubsport993/battcut1.jpg)
3rd Gear
Thank you for all of the fast replies. Is there any chance that you can post up more interior pictures (mainly of the cage) on your RSCS? I'm going to do a custom cage since I can't find one anywhere, and I need as many details as possible. Thank you again!
