Cruise control, over-rev - how bad?
#46
What about the inertia of the flywheel? It has significant mass. Cutting the spark and fuel won't cause the engine to immediately stop. I would suspect it will go through several strokes before friction and compression stop it. It is probably imperceptible to us, since 7000rpms equates out to ~117 revolutions per sec...
#47
From my first post, I could not accept that the engine could accelerate beyond the point of no energy being put to it. But I have come to accept(at least for now ) that the stored energy in the flywheel could contribute to an increase in rpm beyond the point of fuel/ignition shutoff.
Geoff and Geoffrey have conducted similiar tests and have made different observations. The great likelyhood of dissimilar control parameters(weight of flywheel, for one) could resolve this.
To carry the thought to the extreme, imagine an engine, with no flywheel, under the same test. Catastrophic.
Noah
#48
Rennlist Lifetime Member
But a water wheel tends to reach equilibrium (steady speed) quite quickly. When the water supply is stopped some of the "buckets" still contain water so the wheel will still turn but slow down fairly rapidly once the "buckets" are empty.
What we're trying to understand here is the situation where an accelerating system appears to continue to accelerate when force is removed. That seems to me to be a contradiction to the laws of motion. There might be a latent ignition stroke that hasn't finished but other than that there's no more energy being added.
If this were true you could accelerate to 60 mph and at exactly 60 stomp on the clutch and the car would continue to accelerate. Or a skier accelerating down a ski slope would continue to accelrate once hitting a flat section. Force = mass times acceleration or accelearation = force dividied by mass. When Force = 0 then accelleration must =0 or perpetual motion is just around the corner.
(I spent a year as a Physics major before I changed to applied Math because the girls were slightly better looking.)
From Charles Probst's book "Bosch Fule Injection and Engine Management" there's a paragraph titled "RPM Limitation" under the Motronic section. It reads "If the RPM signal is greater than max-allowable rom stored in the computer's memory the control-unit signals a cutback of the fuel injection waunity. A scope set to read four pulses for simulaneous injection for four cylinders shows the limitation cutback of every other pulse, one pulse every other crankshaft revolution."
#49
Originally Posted by N51
Tom,
Noah
Noah
once energy stops being added, the engine will CEASE TO ACCELERATE. The inertia of the engine will keep it spinning, but NOT ACCELERATING.
#50
#51
Originally Posted by phelix
I'm in vehement agreement.
The energy stored in the flywheel does not and cannot exceed the energy required to increase the engine rpm's beyond the point of fuel/ignition cutoff.
Have I got it right, yet?
Noah
#52
Originally Posted by Terry Adams
Done that a couple times. Did not hit rev limiter, though. No harm done.
#53
#54
And I'm still listening. :-)
Noah
Noah
#55
-Jim
#56
Just to bring some heavy duty stuff in , how do you think an F1 motor is inhibited at 19,000 rpm +/- 50 rpm ? with the accelerator on the floor .
Hate to disapoint but its done by rev limit + fuel cut !! Same old stuff that has always worked .
The mistake creeping in is using a moving coil tachometer ( Rev counter ) which has the dynamics of a toffee apple ! The normal car rev counter is to provide the driver with information from a low cost system .It is not precision .
To really understand this a proper data accquisition is needed.
Does that help ??
Geoff
KS400200,the oldest 964 on Rennlist,unless you know differently !
Does that help ??
Geoff
#58
Felix,
When an F1 is in any gear, including top, there is a mandatory rev limit .
It is part of the FIA regulations .
The automatic gearbox is a sophisticated , electronic/hydraulic manual type gear selection system with driver paddle control and not to be confused with the 4 gear Auto shifter / torque converter as in a nice saloon !!!
Does that help ??
Geoff
Does that help ??
Geoff
#60
Yeah, but for the Doofus that started this (me) not so much fun!
My conclusion:
1. I probably have not done any damage in neutral on account of the rev limiter.
2. I will be really careful from now on wrt disengaging cruise.
3. If my "just turned 20K mile" beauty has a fatal malady in the next 100K miles, I'll have to assume point one above was incorrect!
Cheers~!
My conclusion:
Cheers~!
