993 Forum 1995-1998
[B]Window mechanism problems[/B]
Old Jun 16, 2007 | 06:53 PM
gerrard128's Avatar
gerrard128
Default [B]Window mechanism problems[/B]
Hi,
I have replaced a faulty window motor in the passenger door. To get to and remove the faulty motor I had to undo the hex bolts that attach it to the window mech/regulator that attach it to the door. Now I cant get the mechanism to line back up properly to be bolted back to the door. The hotizontal bar of the mech nearest the door latch that is secured by a bolt at either end just wont line up when the rest of the mech is bolted in the middle of the door and the motor area.
There must be a method to doing this e.g. window in a certain position, attaching the mechanism in a certain order?
My window is currently held closed with a wooden choc so any suggestions would be great!
Thanks, Mike
