Horn Installation
I just couldn't close it up without taking pictures to post here, so here you see the final installation. I didn't take any pics along the way, as I was never intending to write a DIY.
This is the right front wheel well, looking toward the front of the car, with the liner removed, obviously. You can see the stock trumpets and my the Griot's red horn, and the wiring that connects them, as well as the back side of the headlight bucket and a bit of my lovely M030 springs
.I used little "Y" spade adapters so I could put two sets of wires on one of the horn's connectors - the original wires plus the extra ones that run down to the new horn. Cable ties keep things fairly neat.
Looking up at an angle, you can barely make out the L bracket that I mounted the horn on. It is held to the car with a bolt that holds the fender mounting leg thing. The white goop on the horn is some silicon adhesive caulking (will dry clear) to keep the red plastic part of the horn from vibrating. It is not a super rigid connection to the aluminum casing of the horn body.
It sounds a bit odd with both horns going together, but hey, it's that much louder, and that much more obnoxious. Which is exactly what I want in a horn. I must say (and I did, in an earlier thread) that the stock trumpet horns alone do not impress.
Chuck, I thought the red one was the compact one. Bruce, would the larger black horn have fit in that space?
I did not use the included relay, since the car already uses a relay to actuate the horn.
Now that I have both horns installed, I do worry (a litte) about pulling too much current. Have not blown the horn fuse yet!
http://www.griotsgarage.com/catalog.jsp?&SKU=77839
