need help-troubleshooting wiring problem
Following RS wing installation. I tried a search but could not find an answer to this specific problem.
Initially disconnected the retractable rear wing connector under the dash as outlined on Robin's DIY site. I realized that I did not have any interior lights so reconnected that and did the jumper DIY Robin recommended to the connector block in the engine compartment. Now I still have no interior lights and have the rear wing warning light on the dash. ??
The car is a My 95 and had the basket handle break light which was removed with the rear deck. Is it possible that is the problem and additional jumper is needed? Or perhaps I have another problem going on.
Well, solved half the problem today. Went through my fuses (duh) and the interior light fuse was blown. Replaced and the interior lights and trunk light are again working. Still getting the retractable spoiler warning even after I jumpered the #3 and #7 pins as described on Robin's DIY. Hmm?
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
